Allow JOINED schedules
In the world of relational databases there is the idea of a join. A join is a way to combine data from two distinct sets into a third set that contains some data from both. Both sets must contain a common filed that is used to join them together. Examples are a little hard to replicate here so I urge you to look at the Wikipedia entry for joins.
In Revit I find myself quite often wishing that I could create a schedule based on two other schedules that contain a common field. Consider this situation:
I have a large multi-residential project where a number of host files, corresponding to different residential blocks, each contain links to standard apartment unit models. I have some schedules. Schedule A contains a list of all links in the host model. Each link has a unique name. Links that correspond to standard apartment units are named using a global apartment type naming convention.
Schedule B contains a list of all the rooms in the host model. Each room corresponds to a whole apartment. Each room has a Name property whose value is the apartment type (same as what's in Schedule A)
I want to, automatically, create a third schedule, C, that joins schedules A and B on the name property. That is, the resulting schedule will have rows with both the room and the corresponding link. I can then do counts of how many times a given unit is actually linked into the host file and used in my plans.
As I write this I feel like my example is perhaps not the best but I believe that experienced BIM users will see its potential. I believe that this idea is sound and if implemented would provide a new and powerful way to query the model.
cheers,
-tomek
Comentarios
This would be great. Even more, it would finally help us make fast cost estimations: we could join a cost schedule for walls with a cost schedule for windows, and thus have a cost schedule for the whole building by adding the totals of the partial schedules.
Hope this attracts the attention from Autodesk!
Yes, implement the often used database functionality in Revit.
Another database related Ideas - Reports!
Hi @Anonymous
If you wanna go with 3rd party plugins, BIMright has a feature called Category Joins, which is similar to your idea.
https://www.bimright.com/features/categoryJoin
