Joining 2 different wall sweep profiles
I see that there are many people having an issue with wall sweep. The biggest problem is when you want to solve a corner where 2 different sweep profiles meet each other. I would suggest to add blend function for wall sweep or allow Model in place void to cut just the wall sweep so user can cut both profiles in an angle they want.
