CAMBIAR LOS COMANDOS A ESPAÑOL
CAMBIAR LOS COMANDOS A ESPAÑOL , EJEMPLO WA ES PARED , CAMBIARLA A PA
Comentarios
Actually is posible to edit the keyboard shortcut as desired and save the to export to other computer or updated software. Similar like if you have a custom catalog of line styles.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Es posible editar los atajos de teclado en Revit al gusto y guardar y exportar dichos ajustes a diferentes computadoras, incluso utilizarlos para reprogramar los atajos con  dicha lista exportada luego de actualizar a una versión diferente de revit.
https://knowledge.autodesk.com/es/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018...
El estado se ha cambiado a: Archived
This functionality is already available in the software.
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community (votes or comments) over the last 24 months and as such we will not be pursuing it at this time. Please feel free to re-word (titles and clear descriptions are really important) and resubmit this Idea.
