View Region Breaks - Allow Both Directions
There are times where the main content of an enlarged drawing may be far from column grids, but it is still desired to provide dimensions to the grid lines from this point. If one could "break" the views in both the left/right and top/bottom axis of the crop region frame, then it would be easy to crop in the column locations nearby to the primary content -- i.e. curtain wall jamb details, etc. See the attached image for reference. Also, it would be great if one could more easily modify the dimension text after the view has been broken. Often times, you break the view, and then you can no longer grab the dimension text to adjust its placement along the dimension string.
Comentarios
other ideas related to View Breaks (fixes):
and new features:
did u find a solution to this problem.
if yes please share how to do it.
