Move Detached model workset options to Open Dialog
Instead of presenting the "Detach Model from Central" workset options when detaching a model make the two choices available at the Open dialog.
Current options at Open dialog for Worksharing is:
Detach from Central
Create New Local
Proposed change at Open dialog for Worksharing:
Detach from Central and preserve worksets
Detach from Central and discard worksets
Create New Local
Resolves:
Reduces clicks
Unnatural Open document behaviour
Hanging dialog when walking away after clicking Open.
Comentarios
simple & fantastic
I would greatly appreciate it if detaching was made more easy... and perhaps even more clearly, by changing the color of the toolbars when working on a shared model resp. a detached model.
Now we have to be realy very attentive, and it can ruin some days of work when one does to big changes in a model that is, other then expected, not detached...
