Annotation Tag without leader outside fabrication Pipework is losing value
On behalf of a customer from UK let me add the following wish:  annotation tag without leader and placed outside fabrication pipework after turning off leader should keep value of label e.g Centerline Elevation
Top right side - Annotation Tag for fabrication pipework
Bottom left side - Annotation Tag for Duct System Family
Both without leaders and outside duct/pipework should work in the same way and keep values.
Comentarios
This issue manifests when tagging a pipe with a leader/tag. Works fine when clicking on side of pipe, however when the end of the pipe is selected without a leader, the value of the Center line height does not compute or read out.
El estado se ha cambiado a: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
