Automatic join adjacent coplanar surfaces
When two walls with the same surface material are adjacent and coplanar, I would like for the individual surfaces to act as one surface:
- The surface material and patterns automatically align to each other. Aligning a model pattern for coursing only needs to be done once.
- Lines representing the edges of each individual wall are not displayed within the unified surface.
- If this behavior is not desired, there could be an option something to the effect of "disjoin pattern".
