Revit Mass - Conceptual & Actual
Hi
In Revit Conceptual massing, there are some important points i think are a must to be considered in the next versions:
* when create the mass, and load into project, all the mass is considered as conceptual, only the panels or adaptive models are working as final elements, even if i need a surface to act as a final object or item.
* when load a generic model adaptive or any to the mass file, it can not be cuttable, also when load the mass into the project.
i hope these points can be solved.
many thanks
regards,
0
votos
