Negate Condition for View Filters
I wish I could Negate Condition view filters like I do for Find Items in Navisworks.
For instance, When I want two views - one with JUST wood walls, and the other with everything except wood walls.
I have to make the Wood Walls filter, but then I end up making "NOT Wood Walls". I would love a column added to the Filters dialog in VG to check on/off Negate Condition so I wouldn't have to make these "Not" Filters.
Comentarios
I saw something like this in Autocad Layer Manager: select one layer, right-click on it and choose "Invert Selection" or "Invert Layer Filter" . An "Invert" option would be great.
The filter builder in Navisworks isn't exactly the template I would prefer, at least not the implementation.  Given the option, I would prefer something else like the SQL expression builders I've come across.  They're easier to use especially with complex searches e.g. [this] AND ([that] OR [something]).
I'd love to see the same concept when assigning the Visibility parameter in a family.
Lots of families have two sets of geometry, and they each need a Visibility parameter.
Parameter 1: "ShowThis
Parameter 2: Hide This = not(ShowThis)
If we could specify not() directly in the Visibility of the element, we could significantly reduce the number of parameters in the Properties
