Rebar Creation Error
Unable to align rebar to beam cover. Please visit the attachment.
While creating rebar in beam as host, rebar must accepts beam’s cover or column’s cover. Which one is logic.
Please handover this issue to rebar development team and make them to correct. I found, not the problem with moving rebar. If middle of the rebar, places in the column, rebar accepts from beam cover to column cover. This problems are resolved in other rebar software. Consider this issue as friendly request and make Revit as more efficient software. https://autodesk-communities.force.com/customer/servlet/servlet.FileDownload?file=00P3A00000bTNbRUAW
