Dimension Leaders Should Be Allowed To Float Along Dimension Line
Tags default to "Attached End", but allow you to toggle that off so you can move the leader to a place that is more readable. Dimensions, on the other hand, force the leader to attach only to the middle of the dimension line. Very often, this location is where another element's edge line crosses the dimension. It would be very useful to allow a free end on dimensions as well.
