Draw order in linked dwg file not respected in Revit
Just encountered this problem and found a tread in AUGI site that totally explains the problem and the bug. This is unaceptable...
http://forums.augi.com/showthread.php?43458-DWG-Import-Draw-Order
I keep encountering bugs to fix and posting them here. Autodeks should start to focos on fixing known problems before trying to creat new features that can bring new ones... No?
Comentarios
I found a potential solution to your issue. Revit follows the 3D order of objects. Instead of bringing lines to front, they might actually be lower along the Z axis. So if you move them over by moving them up in the z-axis, I think that would address your issue.
