Easily Add Drafting Views to Sheets
It would be nice if there was a way to easily add "Drafting Views" (or any type of view) to sheets using a one-click method. Instead of having to drag the view to a sheet, if there happened to be a way we could right-click on the view and have an option to "Add to Sheet." A dialog box could appear and you have the option to either add it to an existing sheet or to a new sheet. After you select new or existing sheet, it would send you to that sheet and allow you to place it where you would like it to be placed.
Comentarios
duplicate idea: right-click to add a View to a Sheet
similar idea (ALL open views): Place open views on sheet
Hi there, I created a plugin that i think could help you with this.
It allows you to place views on a sheet incredibly fast.
huge time saver.
check it out here:
https://apps.autodesk.com/RVT/en/Detail/Index?id=9040274247571226768&appLang=en&os=Win64
