Translucent Options
You are able to make beams, slabs, columns, filled regions etc "translucent" by setting the transparency number to 50 (for example). Text (Tags) on the other hand, have only two options for the background -- Opaque (which completely hides everything behind the box) or Transparent (which often results in unreadable text). Most other programs I've dealt with (including Bluebeam) give you the option of gradations between the extremes. The most common problem this creates for us are that tags for beam sizes (automatically at the center of the beam) often hide the ends of beams framing in from the side (or result in unreadable sizes). A ghostly version of the framing beam would make it more clear what is happening.
