Building type and Space Type create the user parameters
Why could not I add the user parameters ?
For example, in different spaces different temperatures.
The air change rate should be set for both supply and extract.
It is desirable to have arbitrary parameters.
This introduction allowed us to have a wide range of calculations.
With the use of dynamo.
