Architects and interior designers need more than just functional program. They need to work with a color but this is unrealizable with Revit, so user has to use 3ds Max even to see the color that is assigned to the object.
How colors change - https://youtu.be/RXyw2DnVGKg
Possible solution of this issue could be creation of a new view “Diffuse” with special properties:
- Switch off all highlights effects;
- Switch off Bamp;
- Switch off shadows of the edges;
- Switch off textures;
- User can control the main shadows of the object
Thereby we will get an additional view with materials colors from section “visualization”.
