When creating a beam system, it is not possible to specify the displacement of elements relative to the plane on which the beam system is located. This is very important if the beam system is located on the surface of the element and it is not possible to specify with offset, such as roof rafters, beams or sticking out or in the body of the element and there is no way to indicate the exact location relative to the surface.
