Realistic Wall Joins & other
Please see the attached photo- I would love to see my contractor build that "corner".  This should NEVER be a default wall join! I can't think of any reason this would actually be useful in the real world.  Some of my wall joins change randomly and it is very frustrating to keep making it correct from something that does not even work- Sometimes it happens right before I am finished, and in large projects, you may not notice before you print! Dangerous!!
While I'm here..
-A disjoin option that DOES NOT delete dimensions would be awesome.
-Materials are very difficult to get correct for rendering- the rendering appearance in the material browser should actually look like it will rendered.
-It would be great to actually know what some errors are from - the "expand" button is usually useless.
-Sweeps that can change planes & angles.
-Easier Sheet layouts!!! It takes way too much time to layout sheets where everything lines up- This should be the simplest task.
-Automatic Date change on sheets
-Don't change the text size or spacing again because we have to update all the messed up text in our upgraded projects... not cool.
-Backwards compatibility.........
-Don't make us pay so much to upgrade if you don't actually change anything useful.
I am also very curious why Revit isn't available for "Product Feedback" -because they know they will get slammed with too much?
TTFN
Comentarios
Here's another default join... I totally want my drywall and framing to intersect like that.. totally.....WTF?WTF?
