Label wrapping using hyphens
Hi all (first idea, please be gentle)
Can the text wrapping feature be modified to treat hyphens as spaces?
Currently, I can only create multi-line labels if I add spaces, but I want labels to act the same way if they include a single string using hyphens.
Example below is a drawing called '7001-ABC-01-01-DR-A-0001', to create the image below I've had to instead use '7001-ABC 01-01-DR A-0001'
Comentarios
