I would like Revit to allow a demand factor of 0%. Currently the lowest possible percentage is 0.01.
The reason I want this is so I can assign it to a Non-Coincident load type that I can apply to Non-coincident loads. That way the connected loads are correct, but for the demanded load, all non-coincident loads would be zero. This is used with loads that are never 'on' at the same time, like interlocked pumps, for instance.
Thanks.
Armand
