Area Reinforcing continuity through slab depressions
Disable the tendency of area reinforcing to treat slab depression families as an opening through slabs and only cut the reinforcing that is actually intersected by the depression.
i.e. Area Reinforcing used as bottom steel mat to run continuous under the depression but cut or (or lower based on concrete cover) any top bars placed by Path Reinforcing that intersect the depression or opening.
