Revision Clouds should be stretchable, like filled regions!
This is pretty crazy that you have to go through "Edit Sketch" if you have to stretch your revision cloud box! Why isn't it like filled regions that allow you grab the arrows and stretch it in or out? C'mon Man!
Comentarios
You shouldn't even have to do such a thing! It should modify itself to accommodate text edits, like balloon texts does in Word or Excel. Revision Clouds should be (self-adjusting) parametric objects by default.
