Create close loops from loose lines for boundaries
I often need to define my own boundaries for beam systems. The result is some loose lines that I have to close using the trim/extend to corner command.
It would be easier if it was possible for Revit to close the boundary loop automaticaly, maybe with a "Close the loop" option. This would be helpfull to other boundary elements as well.
Comentarios
it should be easier to handle and tools shall identify it's properties and it's functions , if any one do mistake , it shall help itself to help in the difficult segements.
