Shared Parameter of Type FamilyType
Please add ability to create shared parameters definitions for parameters with Parameter.FamilyType and set desired DATACATEGORY.
See this discussion for further details: https://forums.autodesk.com/t5/revit-api-forum/shared-parameter-of-type-familytype/m-p/6456464#M1757...
Comentarios
The problem continues in 2018. And we can not create a shared parameter with FamilyType. Since the parameter file is unusable and fails to read it in Revit.
Is this so difficult?
We need to make an exact copy of the file of shared parameters, to rename them, and the FamilyTipe information group always gives an error when not taking the correct value.
Another black hole of Revit, which seems not to solve.
