be able to set v/g (Visibility/Graphics Overrides for multiple Views at once
I've found myself wanting several times lately to be able to select multiple views in the Project Browser and change V/G settings for them all at once. For example, I don't want to have to make a separate View Template for each Design Option, so DOs are not included in the template, but then I need to individually go to each view to set the DO (see also Set Design Options via View Schedule for an alternate idea).
Common settings to all selected views would show up normally. If there was a variation between views, then the setting would be blank (as with properties, when multiple elements are selected that differ), but allow the user to chose a setting to apply to all (just like properties). It might get complicated to implement for all the Model & Annotation categories (how would you show what's common & not?), but for the major settings ("[x] Show _ in this view", Design Options, Worksets, etc.) it shouldn't be too hard.
Another related solution would be partial View Templates: View Template include subcomponent from other template, View Property Templates for View Templates and Parent / Dependent View Templates.
