Standard distribution of rebar is a constant spacing only. It is inconvenient. You need to add two more layout options: "With additional spacing" and "Formula". These ideas have already been published earlier, on other resources: 1, 2.
1. "With additional spacing"
"Maximum spacing" layout is good because it automatically places the reinforcement set on the entire structure, and the length of the rebar set can be adjusted with "Handles". But the spacing turns out to be inaccurate!
"Number with spacing" not convenient too: the quantity must be specified manually.
In practice reinforcing bars will be mounted as follows: several rebars with spacing "200", and the last with a reduced, "additional" step:
Now I need to put the bars first "Number with spacing", and separately put one rebar at a distance of 140. It's horrible and makes me cry.
We need new rebar distribution layout "Fixed spacing with additional rebar".
The properties should be able to switch the "Additional spacing" - "At the beginning" or "At the end".
"Rebar presentation - Show first and last" must show the first and last in the zone with a constant interval, "Multi-rebar annotation" should work the same:
"Rebar by area" and "Rebar by path" must have the same setting.
2. "By formula"
When reinforcing columns and beams, it usually requires the installation of transverse rods with a variable step - a step smaller at the end, more - in the middle:
Now I have to use 3 different sets of rods. This is inconvenient, especially when editing - three times as much work.
The method "By formula " should work like this:
"Rebar presentation" and "Multi-rebar annotation" should work in the same way as in method 1.
For "Rebar by area" and "Rebar by path" this method is not required.
