Change Wall attachment behavior
I would like to propose the following changes to Wall attachment behavior: 1. Wall height to reflect the current\actual current height. Currently, it shows wall height PRIOR to attachment. 2. Add an indicator in the instance properties window about the wall being currently attached. 3. When attachment conditions no longer physically possible, leave wall height as is, IF changing current height leads to hosted elements getting deleted. 4. When attachment conditions no longer physically possible, automatically remove attachment and joined geometry conditions, instead of generating unnecessary warning.
Comentarios
#2 is already done. Walls that have an attachment have a check mark in the properties palette.  Does that work?
And for the wall in the image what should the reported "height" be when attached like this?  Highest point of attachment, lowest point of attachment, or listed as "varies"?
Thank you, Jeff! Well, first of all and before I talk about this issue, I think I just caught a cute little bug :cara_con_una_leve_sonrisa:
https://www.screencast.com/t/KVodrR39WY0A
I think the height should be the actual dimension IF the wall has consistent height, and VARIES is it's sloped like you suggested.
If I may also suggest, this change should also apply to profile-edited walls, and attached columns.
Do you think there will ever be a "Structural Walls" category?
