Lock Align of Topography Points
Don't know why nobody complain about this yet... I guess people are just used to having revit topography to be time consuming.
The problem is the following:
Imagine you have a topography width some pads locked to reference planes. Some topography points are probably laying on those same alignments.
I want to be able to change the position of both by just moving the reference plane.
Although I can align/lock everything, when I try to move the reference plane the topography gives an error and don't comply with the request.
I have to manually enter the topography and move the points again.
This process as to be inverted in the case when those reference plains/pad limits correspond to the border of the topography (This was the case I tried and really needed to work).
That total sucks and is very, very, very time comsuming. Please correct this bug!
