Ability to have block objects in CAD format when exporting 2D plan
I would like to ability to export 2D plan in CAD format gives me block object especially electrical fixture for quantity take off purpose in CAD format.
Thank you.
Idea submitted on behalf of customer from Vietnam.
Comentarios
it would be useful to control which category or element to be as a block when it's exported to CAD format
because not all categories or elements exported as block, once it's exported it's exploded
actually this is my idea
From an AutoCAD user...
When I get files in from engineers using Revit, I don't get devices as nice blocks - I get individual lines. Makes it difficult to resize, move, etc as I work on my drawing in AutoCAD. Can this be changed?
Example, a fire alarm horn/strobe is usually a square with a letter in it and a triangle attached, or some variation. One block, or 7 lines and a letter.  Which would you prefer to work with??
Revit
@BiedyIt's not the Hammer. It's the way you hit!
Tell your engineer your problem.
He should be able to solve this problem.
This is a link for sample File out of Revit (ACAD 2019 DWG) with exported blocks of Symbols like Smoke Detector and so on.
Kind regards,
Bernhard
