Subcategory for FILLED REGIONS
Create the proper subcategory for FILLED REGIONS, this would help a lot to improve DWG exports from our sheets
Comentarios
It would also greatly help when changing the V&G Settings of  a view.
Bumping this. Seems like a pretty simple thing to impliment and would help with all those drawings that are more diagramatic or illustrative - which have to sit over the live model.
This also makes it possible to better coordinate between disciplines without having to customize the VG settings of links.
That would be great!
Not great. FUNDAMENTAL!!!
We need this to control symbol visibility (alternate between detail item and annotation symbol in different views).
There is no possible workaround now.
This change would create more consistency and open up other possibilities. It would be possible to have separate Filled Region Schedules where you could schedule the Area parameter. Additionally, if you have a Filled Region Tag, you could tag the Area. We need to use way too many workarounds now to achieve this.
