Rotate object
I want to be able to tell Revit to NOT rotate the objects in a Radial array by default...similar to AutoCAD.  Alternatively, have the ability to specify the rotational value of each object in a Radial array.
Comentarios
Do you mean like seats around a scene?
yes yien_chao....it would make sense to be able to tell the software to rotate the seats around a desk during the radial array or not rotate them.
