Split Command Control
When using the Split command in Revit (with a gap feature), be able to control the size of the gap via graphical interface instead of assuming the split spacing is equal on both sides of where I click. In other words....the split command with a gap assumes that a 2" gap will put the gap in equally 1" on each side of where I click...I want to be able to control that spacing location to allow from either end or middle.
