Show actual paper size in print dialog
In the Print dialog show that actual paper size after selecting a Paper Size. When working with drawings from other clients we can measure the actual size of the sheet...but we may not know what the name of the sheet is in order to select the proper size in the dialog (A2, A3, A4, E, E1, Statement, Folio). It would be nice to be able to select the sheet name and then also be able to confirm that it is the correct size.
