Editable / custom walls
Can you make walls floors and roof editable, I. E the system families. It's real restricted as of current. If not can you add in more forms of wall build ups like cross laminate, stud wall, shingle cladding, corrugated steel cladding, etc...
Comentarios
Maybe I misunderstand your request but you can achieve pretty much any build up by editing the appropriate system family. Simply duplicate and then edit the layers assigning desired depths/thicknesses and materials.
Hi Tomek,
Im not long at revit, but what I ment was that you can't generate a wall
buildup detail nessaseraly to the way you want. The reason being; each
layer in your wall systems family can only be then edited as a single
volume. In my circumstances I would be thinking of an external wall build
up as; a stood wall with insulation in between and then cladded externally
with timber shingles. So for the reason that I can't create a wall family
where I can build in individual elements that can have parameters
quantities, etc... attached. I. E centre to centre studs, insulation
in-between, etc... I think editable system families should be added to
revit. I. E of current if I have a battoned wall the best I can do is have
a solid timber wall layer show in my detail.
I haven't been doing it long, but if you have a solution to this please let
me know.
Regards
Corey
