Extend the possibilities of Revit Formulas
Operation Result Notes
| x in s | True if an item of s is equal to x, else False | (1) |
| x not in s | False if an item of s is equal to x, else True | (1) |
| s + t | the concatenation of s and t | (6) |
| s * n, n * s | equivalent to adding s to itself n times | (2) |
| s[i] | ith item of s, origin 0 | (3) |
| s[i:j] | slice of s from i to j | (3)(4) |
| s[i:j:k] | slice of s from i to j with step k | (3)(5) |
| len(s) | length of s | |
| min(s) | smallest item of s | |
| max(s) | largest item of s | |
| s.index(x) | index of the first occurrence of x in s | |
| s.count(x) | total number of occurrences of x in s |
