Copying between Views
The ability to specify a base point when copying objects from one view to another, rather than pasting it into random space and then moving it into place
Comentarios
You can Paste Aligned to View or Aligned to Level to ensure the object gets placed in the same position.
Yes you can, however this is more directed to when you are copying notes or detail components across detail views which do not align
