Show Stiar in Section - Show Stair Part that behind the Section Line
hi
In Drawing Sectian Must show stair Part that behind the Section Line but this Dont Show in Revit Section
Comentarios
Is this a "how-to" question or a proposal for Revit improvement? Questions should be posted in the Revit Forums, not the Ideas.
If it's an idea, you might want to elaborate.
this is Idea
My Drawing Section Must show stair Part that behind the Section Line but
This can be added to Revit
In the Autocad , I am Drawing Line Stair part that behind the section Line also in the Revit  must Drawing Line Stair part that behind the section Line
I mean's Automatic Show Stair Line part that behind the section Line
i think this option already in  revit in view tab
@Anonymous As far as I know "Show Hiden Lines" only works on geometry in front of the cut plan, not behind it.
No , "Show Hidden Lines" Only Show the Line in View, Don't Show behind it
HIDE RAILING DIRST THEN SHOW HIDDEN LINES THEN UNHIDE RAILING BACK
