If i select all walls, push RMB on it and select "Change orientation wall"
only one wall will change it orientation
need to be changed orientation of all selected walls
Unfortunately , I don't know ur language
but any way select all walls u want then press on spacebar , it will all going to change its orientation
Yes, but context command works another way and changing one from all selected walls only. This is very confusing...
