Split Topography Method
The Topography API currently provides a wealth of options for creating and manipulating Topo's.  One important method missing (that is part of the UI) is Split Surface.
It would be great if you can provide a method to Split a Topo Surface.  Something like:
TopographySurface.Create(document, curveLoops, sourceTopoSurfaceId)
A similar method already exists for creating Sub Regions:
SiteSubRegion.Create(document, curveLoops, hostTopoSurfaceId)
Comentarios
This would be a welcome addition, especially for use in Dynamo. There are many cases where structures need to 'cut' the toposurface and this is currently a manual task
I really need this method to be available, it would be a greate adddition. I was going to start a new plugin to automate this task and can't find anything about.
I'm working on a linear toposurface  and want to cut it into pieces alone the centerline, but I can't find the right api to finish this task.  So  Split Topography Method will be useful. Please consider to add it in future.
