For labels, the color of the marker line does not match its color, whereas for text notes it does.
Which version is this?
Text was changed in 2017, but not Tags
Tags got the same rendering engine in 2018 as Text, so they should match now.
I haven't tested this myself, but if you're still in 2017, you should try it in 2018 to see if its already been fixed.
Come on AutoDesk,
Add colorselecting to the ArrowHead system family (or subcategory selection which defines color and maybe even linestyle)
Also add a "None" arrow style if we just want the leaderline and no arrow.
This shouldn't be to difficult to implement, should reduce te amount of filters and selection to be made and to keep in sync with changed.
- Michel
Please user Upvote this idea, it's not in Revit 2020 and don't think it's in 2021!
