Worksets and Components/Elements
When enabling worksets (converting an existing developed file into a central) it would be great if the user is prompted by a table, whereby, the user can determine which elements/components within the existing file should fall under which workset. The table should enable the user to name the workset they would like and choose the components that should fall under that workset.
Comentarios
