Ployline
why we can't draw polyline in Revit, it required for some calculations & presentation
used also by pick tool
Comentarios
@ipselute,
yes filled region can be used instead of polyline but this work around is consuming time
we need a clear object to draw polyline with corners as in autocad ,
this option is too easy to implement since it can be found in other autodesk programs
why such these simple option are not in revit
why can't i have line or poly line which i can get its length in schedule and tag it or access it with API modules
i open the page but can't find the relation between the page content and my idea here?
