Edit splines by grips
Currently, splines can be edited only by moving a point which is the intersection of two tangents to the spline. I would like the option to edit splines by grips, such that when I'm creating a spline, the line will pass through where I click. This is how AutoCAD draws splines (unless you change the settings) and makes splines much easier to work with.
Comentarios
Do this for arcs too, please, not just splines.
