In plan view, if there is a pad above the view range cut line, there is always a blank hole where the pad is. Since this is just the cut earth why not show the fill as is the case in section view?
I have had to make the pads (I realise people hate pads but I find them useful if there are a lot of changes in the initial stages) metres thick and apply the same cut fill as the surrounding topography to get around this. This doesn't make sense in reality as shouldn't the pad be only as thick as the substrates under the building?
Please, no more blank holes!!
