It would be nice to have Dynamo Player dock to Properties Palette and Project Browser, so that Player always stays open. I think more users would be inclined to use Player they we had the option to dock it like other palettes.
Perhaps being able to create a ribbon in the UI would be nice too. Assign specific scripts to buttons with a custom icon. Perhaps give a floating window when running the script so that you can still use the "customize input" feature.
Due to the number of apps, the vertical scrolling nature of Dynamo Player might make more sense as a palette than a Ribbon Tab. The nice thing about a palette is you can dock it BEHIND the project browser, and only pull it forward when you need it. It would seem Dynamo Player cannot be continuously open AND out of the way. Not sure if Dyno has this capability.
Will definitely take a closer look at Dyno, thanks.
