Rehost element- preserve relative location
It would be great that if you are rehosting an element to something that is parallel to the previous host, the location should be preserved relative to the original location. So if you are rehosting a lighting fixture from one ceiling to another or plumbing fixture from one wall to another, they shouldn’t rotate or move- it should just relocate. If it’s moving to something that is not parallel, for example rehosting model lines from a floor to a ramp, at the very least it shouldn't rotate. As an example I had curved parking striping that needed to show on a ramp when previously it was hosted to a flat floor, the lines rotated randomly and it was challenging to relocate them correctly
Comentarios
