Customer Enhancement Request:
A) We would like to be able to modify the gap in the walls after we have created them. Currently one would need to recreate the wall or manually modify the length/width of the wall, if the gab were to be changed - the option to do so would greatly improve productivity.
B) Also, we mainly do Tilt-up panel buildings and need a centerline to show the mid-point in the gap so that we may dimension to it and be able to grab it and move it to stretch the walls. Right now we are having to draw a detail line and copy it each time to each panel joint but of course when we move it the panel joint doesn’t move with it. We then have to create an offset and then trim the walls back to that point. I understand that not everyone will want to see a centerline so I was hoping there could be a feature where you can check a box to turn it off or on.
At the moment the feature doesn't generate a separate component referenced as the actual split, which is probably why it lacks the options to be modified. It simply splits them into two elements/walls and leaves it afterwards.
All in all there are room for improvement on that side.
