Tile the views -- let ME control which goes where
When I tell Revit to tile my views, I need to be able to choose how they're laid out.
If I have 3 views open that need tiled, then one of them takes up half the drawing area and the remaining half is split between the other two.  I want to control which view is the biggest.
I'd also like to control whether the first split is horizontal vs vertical.
Comentarios
And here's a related request for after I've got the layout the way I want it.
http://forums.autodesk.com/t5/revit-ideas/i-ve-tiled-my-views-the-way-i-want-them-let-me-save-their/...
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
How do I upvote the the bejeebers out of this suggestion??
It is required.  I generally don't see or hear of many or any people using tiled windows, purely because you can't control them, the end result is a supplied design function that has minimal use.
'Of course' a user would want to control the window splits, when would you not want to?  The two functions go hand-in-hand.
Looking forward to when it's implemented.
I agree with Matthew and Doni49. It would be really nice to tile a plan and elevation view so they are stacked vertically rather than horizontally - Revit's only option. Please reconsider this request. Matthew is correct. The tiling mode isn't used much because it doesn't function like Windows is meant to function.
Tile the views would be very nice to have some controls over it
