In Revit the save selection feature can sometimes be a big time saver. But the selection feature doesn't let us filter using advanced parameters(like radius, thickness etc..). While this feature is available for visibility filters in Visibility Graphics window, the same feature can be extended to selection as well.
Creating filters to change the visibility graphics of elements with particular parameters, at the same time being able to select(load selection) them whenever necessary for changes.
