Do not Flatten Imported 3D DWG Linework
Currently when you import a 3D DWG and then explode it, all of the elements flatten onto the horizontal plane. This makes it useless when you are trying to bring in complex 3D geometry to snap to. When the user explodes an imported DWG there should be an option to either flatten to the level it was imported to, or not flatten.
